DOUGs Web Site
Date:  7-22-2018
Number of Hours:  0.50
Brief Description:  Installed wing strobe / position lights wiring
Venita helped me flip the assembly over and I drilled out holes in the spars for wire grommets, ran the 6-cond wire through the channel and grommets and then tie-wrapped the cable in place.
root end wiring
root end wiring
tip end wiring
tip end wiring
wire routing
wire routing
