Brief Description: Riveted right wing bottom skins
I riveted the two bottom skins being carefull not to rivet areas of overlap for the top skins. I also left the bottom step skin unriveted until I fit the top skin. I just realized that the manual says to fit all of the skins before riveting the ribs. Well, I didn't but everything seems to fit very well, so we'll see how the top goes.
I drilled out the holes for the two larger inspection hatches to accept the 4mm rivnuts. The smaller hatches have .125" holes so it would appear that they are meant to be drilled out for 3mm rivnuts. I don't have any for this kit, but I do have an abundance of M4 rivnuts. Ofcourse the manual doesn't say anything about it. It's not that big of a deal, but I just don't like researching stuff that should be perfectly clear and not waste my time.
