Brief Description: Installed bottom skins to right wing assembly
My wife Venita helped me flip the assembly over so I could start on the bottom skins.
I primed the mating surfaces of the two bottom skins and the stringer, test fit and aligned the bottom skins to the right wing assembly and installed clecos.
I had one row of holes on the spar cap that didn't line up very well, but everything else lines up nicely without any buckles or bulges, so I will match drill those after I have riveted everything else. I think its probably due to the thickness of the spar separating the caps a bit more than designed.
