Brief Description: Completed Tailboom Support for Trailering
All Finished!
Image #1 shows the 1 1/2" o.d. aluminum tubes with the epoxied and riveted aluminum inserts threaded to accept 5/16" rod ends. They are attached to the 3/4" wide by 1/8" thick formed and welded "T" bracket.
#2 shows the cross brace bolted to the supports to prevent vibration or resonance during the trailering.
#3 shows how the brace will be stowed during the disassembly of the support
