Brief Description: Tailboom Bracket for Trailering
The "T" bracket consisted of 1/8" thick by 3/4" wide 4130 steel. Two pieces heated and bent to 90 degrees and welded. 1/4" bolts were used to attach the bracket to the 3rd bulkhead of the tailboom. 5/6" hole was drilled in the vertical portion for attachement of the rodends.
