Davids Web Site
Date:  6-5-2020
Number of Hours:  1.50
Brief Description:  Stainless Steel Heat Valve
Swapped out the aluminium heat valve that came in the vans kit with a stainless steel heat valve from Aircraft Spruce. Drilled the top hole for the starter relay in the firewall for a #3 bolt. Installed a #3 platenut on the rear side of the firewall.
