Finished up the wiring harnes for the LR3D Primary Alternator Regulator and the SB1B-14 Standby Alternator Regulator. Both Regulators are mounted on the instrument acces panel door so I had to ensure i had enough slack in the harness for the door to open to its full range.The terminal connections were all secured on the back of the regulators and the harness ran to the appropriate locations on the grounding panel and the Garmin P-1 CPC
