Brief Description: Modified armrest and throttle quadrant Part 3
Continued construction ofthe armrest. Match drilled the armrest the the outboard support angle for #8 screws and dimple countersink. Cut to length the inboard support angle piece. Match drilled to lthe armrest, dimpled armrest and machine countersink support angle. Primered both pieces and riveted together. Cut out the templet for the forward portion of the throttle quadrant panel. When I was happy with the fit I cut out the panel from .025 sheet.
