Davids Web Site
RV-8
Rudder Pedals and Control Cables.
Today we started mounting the rudder control cables and assembling the flight adjustable rudder pedals.
Fed the control cables from aft to front the bushings in floor bulkheads.
Assembled and installed lthe rudder cable supports to the F805-L-1 & R-1 floor support angles.
Temp bolted the aft end of the rudder cable assemblies to the rudder control horn.
Attached the WD 817 Rudder Slide Bar and WD 818 to the Firewall and Floor, then
Match drilled #12 the two holes on the WD 818 and WD817 slide bar.
Flinal drilled the 1/4 hole in the WD 816 Rudder slide that receives the locking pin
Rudder Cables Thru Bushings
Rudder Control Horn attachment.
Assembling Adjustable Rudder Control
RV-8 Home
678
Brake System
Electrical Wiring
Elevator
Fundamentals Class
Fundementals Class
Fundementals of Buil
261
Practice kit
