Davids Web Site
RV-8
Firewall Pass Thru Locations Part 1
Started Installing firewall eyeball cable pass thru's for the throttle, mixture and propeller control cables. Used a large step drill to make the hole.
Cable Pass Thru Template
Screw holes located and drilled
Eyeball pass thru temp install
RV-8 Home
678
Brake System
Electrical Wiring
Elevator
Fundamentals Class
Fundementals Class
Fundementals of Buil
261
Practice kit
