Removed the airplane wheels and Brakes. Installed the brake line fittings with sealant and connected TS Flightlines brake lines between fittings and tightend down. Reassembled the wheel and brakes using longer bolts from Flyboys Accessories and attached their cool permanent jack points and retorqued the bolts. Set the tension on the wheel nut and drilled #30 for the cotter pin.
