We finished fitting the 2nd. spinner filler plate and riveted it to the aft bulk head & we drilled and installed all the nut plates on the forward bulk head. See Image #1. This finished all on the spinner. We didn't install the spinner because we still have to torque and safety wire the prop bolts, but it is ready!........ We then routed the heavy starter wire by installing 2 Adel clamps and one stand off on the oil pan. We also needed a cable tie on the engine mount to get the cable routed over to the starter solenoid. We then fabricated a 16 g. ground wire to run from the solenoid to the starter. Both can be seen in Image #2. This completes the wiring to the starter and the alternator. I can't wait to see how they work! We still need to install all the cylinder head and exhaust temp probes. THEN, maybe we can crank the engine!!!!!
