We worked on the sides and front right "nose". I think that it will be OK??? I also installed a very small heat muff for carb heat. I hope with the vertical induction and the newly designed alternate air door on the air box that this will be adequate. I also have a carb temp probe so this will let me know if my setup is adequate. We all know that Frank Eldridge's RV 6A with the old style alternate air setup and the very same heat muff that I have was not adequate. I will be glad to finish the air seals so we can get started on the air box!
