Brief Description: Left frnt, side and floor baffles assembled & rive
Today we marked the front side baffles to fit around the air intake ramp and drilled all the rivet holes needed to assemble the front bulk head, floor, & side baffles on both sides. We then took the left components off and cut the side baffle and riveted all the components together. We also riveted the stiffeners on the "fingers" around the cylinders and planned how to run the safety wire under the cylinders. We made the stiffeners on the outside fingers longer so that they will clear the oil lines by going under them. The wire from the "fingers" on the inboard side will go above the oil lines.
