We worked on the oil cooler again today and finally got all the riveting done, nut plates installed and the spacers cut for the cooler. As seen in Image #1 & #2, the cooler is finally mounted! PTL! As can be seen in both Images, it fits well and is above the cylinders enough that it should get good air flowing through it. The brace on top of the cooler can be seen well in Image #2 and should do much to strengthen the rear baffle.
