Brief Description: Exit air bracket - cabin heat muff
Claude is still sick and so Nell and I again worked together on the firewall forward. I installed the Van's heat muff for the cabin. It fits well and can be seen in Image #2. I am not sure that there will be room for another one for carb heat. I will talk to Keith more. I also assembled the exit air bracket. See Image #1. There is still more to do to get it installed but we are getting there. While I had the lower cowl off for the other installations, I riveted some brackets on the baffle floor. It is surely more difficult to hold the bucking bar and the rivet gun and I will be glad when Claude returns so I will have a riveting partner. Nell says that she is not quite up to riveting yet.
