Brief Description: Exit air atach brackets fabricated
Claude is still sick so Nell and I continued to do some "catch up" jobs. I took the cowls off and fabricated the exit air attach brackets that will stiffen up the exit air area and seal the gap in the lower cowl needed for the 9A nose gear leg. I also tried to figure out if I need one or two heat muffs for cabin and carb heat. The 2 exit/1 inlet muff from Wicks is too small to fit over the 2" tail pipes so I will have to send it back and get another one from Vans. This will reguire two ram air tubes though.
