Brief Description: Finished wind screen-Installed some cowl hinges
Claude is still sick so Nell helped me again today. I mixed up some epoxy with some acetone and painted both the front and the top of the wind screen fairing after putting on some more electrician's tape. Unlike the other day, I waited to pull the tape off after it had firmed up enough to not run I hope. When I left, it looked pretty good. I hope that it still looks OK tomorrow because I am tired of this! While the epoxy was hardening, I installed the upper portion of the hinge on the cowl sides. I first drilled some extra holes in the hinges and then roughened them up, mixed some micro balloons and epoxy and painted it on the inside of the upper half of the cowl. I countersunk the rivet holes and then riveted the hinges in place. I also had a little touch up painting to do on the baffles.
