Brief Description: Clipped windscreen to forward deck
We drilled another hole in the windscreen and roll bar and enlarged it and tapped the roll bar. This held down the right side better and with less stress on the plexi. We then put all the spacers in and then attached the aluminum clips around the base of the windscreen to hold it down. It took 6 clips and we might need one more. We are about ready to start on the fiberglass but are still reluctant to since neither Claude or I have done much work with epoxy. The canopy frame is a bit high on the right side down at the side skirt so we may have to do a little work there before the fiberglass.
