Brief Description: Strobe power supply wired- Throttle quad finished
We wired the strobe power supply which is behind the baggage bulkhead. I tested it and the tail strobe worked. The wing strobes which go in the wing tips are not hooked up yet. (Image #1) The throttle quad is now installed. Aerotronics had put it on with #6 screw nut plates. The nut plates were not the self-locking kind so we installed 2 nut plates for #8 screws which will make the quad much more stable. (Image #2) We had already drilled the firewall for the throttle, mixture and carb heat cables so we fished them through. We had never attached a sensor wire to the fuel tanks so today, we ran some #18 wire from the sender units to the panel to have some pins installed later. (Image #3)
