Today we wired the AOA flap switch, did some dimpling on the forward deck, put on a nut plate for the ground. I talked with Jason at Aerotronics about the ground for the panel and he suggested using this same nut plate for the panel AND the battery. We will run a #8 wire from his grounding block out the same firewall penetration as the p-wires, alternator and battery wires that is just under the ground wire seen in image #2. We also figured how we were going to route the pitot and static lines. They are running across the left side of the spar box and will run through the gear weldment and on up into the panel. We did not have the right nylon connectors so we ordered some from Spruce and some angle etc from Van's to build selves under the forward deck for the AHRS, AOA computer and the cooling fan.
