Brief Description: Raised fuse by engine mount-Drilled rt axle
We raised the fuse up high enough to put the wheels in place. We used the engine mount and raised it using an engine hoist. When it was up high enough we put higher saw under the fuse. It seemed fairly stable but I would not like to see it up here unattended since the fuse is at a fairly steep angle back toward the tail. We will eventually elevate the rear saw horse to get the fuse level again.... We slipped the right wheel into place and marked the spot to drill the axle using a center punch. However this distorted the threads on the axle and the nut was difficult to get off. I then drilled the axle from 12 to 6 o'clock all the way through. I was slightly off and the bottom hole did not line up perfectly making us elongate the bottom hole when we drilled it from the bottom. Tomorrow, I will drill from both sides. Everyhing seemed to fit nicely though. The axle nut was just snug enough to prevent side play but did not restrict the wheel from turning easily.
