We are working on the fuel system now so we assembled the fuel selector valve and then drilled and mounted it and the trim cable venire knob to the selector plate. We then drilled out a foam separator block for the fuel and brake lines to pass through but didn't think they were sturdier enough so we found some "slightly used" nylon blocks and fashioned blocks for the job. We then mounted the electric aux. fuel pump. Tomorrow we can begin to fabricate the fuel line from the valve to the pump. That will be our first go at fuel lines. I think that we will practice using our flaring tool first.
