This morning we thought that we would have an easy time pulling the 2 little vinyl tubes thru the right wing conduit thus finishing the AOA. However, our pull string must have been wrapped around things in the conduit making this easy task hard. We finally got the tubing thru and stuck the blue on the top (for sky) and the green tubing on the bottom port (green for ground) The blue tubing was anchored to the top skin so as to make a loop to prevent water from accumulating and this loop was anchored in place with "GOOP" We then put the bottom outer right wing skin in place with clecoes, reamed every hole, then removed the skin and dimpled every hole. I then primed the skin and we hung it up on the wing so that tomorrow we can begin riveting to close the RIGHT wing for good!
