Brief Description: Installing roll servo (parts missing) and Gretz pi
Claude is still out. I thought that today I could finish installing the roll servo in the right wing. However one of the bolts TruTrak sent was too short so I had to order another one from Aircraft Spruce. In Image #1 you see the servo in place and it is even wired (notice the red white and blue wire at the right of the picture). I also pulled these wires thru the conduit to the wing root. Having reached an impasse with the servo, I moved to the left wing and began working on installing the heated Gretz pitot tube. The first step was to fabricate an angle bracket. It is drilled and clecoed to the rib. We had decided on installing the tube in the bay jsut out board of the bay containing the aileron bell crank. You can see that location and the pitot bracket with the oblong hole in Image #2. There is much more fitting and drilling etc before it is finished. I will even have to get the left wing bottom skin out of storage, fit, ream and dimple it and then cut a hole in it to match the oblong hole you see in the bracket.
