Claude finished covering the dimpling table with carpet and we riveted the aileron hinge brackets to the rear spar. However, I used the pnuematic squeezer on the first 3 rivets and leaned them over pretty badly. I will see if Keith can help me drill them out. We shot the rest and they turned out fine. I hope that soon we will learn and be confident with riveting. We found the rivet callout for the aileron and flap gap fairings and because the inboard skins are already in place, I don't know how we will be able to set the rivets on the flap gap fairing.I tried to find a source of the self-etching primer in the quart size so that I can prime the inside of the push-pull rods. So far, all I have found is in the cans.
