Brief Description: Completed outboard aileron hinge bracket/ dimple t
Assembled outboard aileron hinge brackets, primed with NAPA self-etching rattle can primer, and clecoed in place on wings. Made the 2 aileron stops from angle alum. Will drill upper hole next time and partially set the upper rivet. Claude did a jam-up job building a table for the DRDT2 dimpling machine. He will cover it with carpet and then we will be ready to dimple the lower skins for the wings but will not close the wing for A WHILE.I have ordered a wiring kit from Vans and have the wing tip strobes and nav. lights and the landing light so we can start on wiring the wing.It was 101 degrees today and may have been hotter in the hangar. We drank much water but still almost got "bear caught"
