Brief Description: Connecting Throttle Quadrant to Control Cables
Ok, so I thought it would be a good idea to test fit everything before I start with the finish painting of the cabin, including the throttle quadrant console side and top.
After some inspection, it became apparent you cannot attach the clevis rod ends to the control cables while the throttle quadrant is installed in the cabin. I thought if I just removed the quadrant from the cabin the still having the control cables attached to the bracket might give me enough clearance to do the work, but no way.
So, the only way I can see to install the clevis rod ends to the control cable was on the work bench, and in fact, I'll have to disassemble the throttle quadrant as well.
So, the idea is to install the Clevis Rod End to the Control Cable
