Brief Description: Fitting the Throttle Quadrant Console
Continuing the initial fitting of the throttle quadrant.
First, installed a DG clamp for the mixture control cable to maintain clearance with engine mount and fuel line. I felt I could do this now since I have generally located the control cables through the firewall and gear leg to the throttle quadrant console.
The top side of the console required trimming on both the forward and aft side where the top meets the side console. Otherwise, the top console seems to fit well.
