Engine has new bearings, crank gear bolt, gaskets, rod bearing, fuel pump, pistons, rings, piston pins, rod nuts, rod bolts, exhaust studs, exhaust guides, rocker shafts, thrust buttons, exhaust valve key, intake valve key, cap exhaust valve, oil return hose, magneto harness, spark plugs, intake hose, oil pressure spring, oil pressure ball, tappet body, temp oil cooler bypass, fuel injector line, divider bracket, hose prop governor, starter ring gear, brush assy magneto, oil seal magneto, node bearing, oil filter adapter and filter.
The following components inspected and approved by Power Aviation FAA # ZLZR567L Crank Case, Crank Shaft, Crank Shaft Gear, Rods and Caps, Through Studs, Rocker Arms, Idler Gears, Idler Gear Posts, Mag Gears, Oil Pump Impeller Gears, Fuel Pump Pin, Tach Drive Shaft, Oil Pump Drive Shaft, Vacuum Pump Drive Gear.
• Engine Case inspected via Fluorescent Liquid Penetrant I/A/W ASTM-E-1417. No cracks, Returned to service per FAR 154..213 (b) (2) 11/25/2013 . • Crank Shaft S/N 116643 Stamp # N68 inspected via Magnetic Particle Inspection I/A/W ASTM-E-1444. No Cracks. Returned to service per FAR 154..213 (b) (2) • Remaining Engine Parts (qty 29) inspected via Fluorescent Liquid Penetrant and Magnetic Particle Inspection I/A/W ASTM-E-1444 & ASTM-E-1417. No Cracks. Returned to service per FAR 154..213 (b) (2) • RSA-SAD1 Servo Fuel Injector Overhauled by Avstar Fuel Systems, In.c FAA #V1RR580Y
