Secured the Static Line through the fuse using a combination of snap bushings for pass-through, and cushion clamps to secure the static line.
I fit in the fuse - barely.
• Located places to drill for the AN3 bolts to hold the WDG cushion clamps in the fuse. • Drilled a pilot hole, finished with final hole • Installed cushion clamps with AN3 bolt, washer and nylock nut.
