Brief Description: Add static pressure line to ports
Fitted the 1/8" clear tube to each static port, routed as specified and measured to length for T-connector. Soaked the 1/4" clear tube in hot water to allow the tube to fit on to the T-connector, still pretty difficult to accomplish. Actually placed the 1/4" clear tube in the vise to allow for pushing the T-connector without collapsing the clear tube. Had to be careful with this operation.
Then slid the 1/8" clear tube in the 1/4" sleeve on each T, then used clear heat shrink tube to make sure all the connectors for the 1/8" tube are selaed.
Installed the static pressure line on both the static ports, and routed and used cable ties to secure the line. Routing the 1/4" line forward to the instrument panel for the static instruments.
T-Connector with static pressue lines
Installed static pressue line to ports left and riight.
1/4" OD sleeves on 1/8" clear tubes, then heat shrink.
