My RV-8 Build Log
RV-8
Canopy Skirt Joint
After securing the cover on the canopy for the canopy rail, applied a heavy coat of a think mixture of micro balloons and epoxy to the cover for sanding down to a smooth intersection between the cover and the canopy halves.
Canopy Joint Cover
Micro-balloons and epoxy
Initial Sanding
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
