After the epoxy set up overnight, started sanding the intersection fairing of the windscreen, top skin and canopy. Used 80 grit to start with applied to a sanding block to remove the high spots.
Sanding Block with 80 grit
Initial San ding of fairing at windscreen and skin intersection
Initial Sanding of windscreen fairing - long way to go
