My RV-8 Build Log
RV-8
Rudder - Continue Build
Continued building the rudder...
RTV'd the rudder stiffeners inside the trailing edge skin.
Completed riveting the skin where in common with the top rib, counter weight balance skin, vertical spar, bottom spar and bottom fairing attach stringers.
Progress on the new rudder
Skin riveted to structure
Need to roll the forward edge
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
