My RV-8 Build Log
Date:  8-2-2014
Brief Description:  Securing the Static Line
Secured the Static Line through the fuse using a combination of snap bushings for pass-through, and cushion clamps to secure the static line.
I fit in the fuse - barely.
• Located places to drill for the AN3 bolts to hold the WDG cushion clamps in the fuse.
• Drilled a pilot hole, finished with final hole
• Installed cushion clamps with AN3 bolt, washer and nylock nut.
Static Line thru Panel
Working in the Fuse
Working in the Fuse
