My RV-8 Build Log
RV-8
Put the Emp back on the Fuse
In order to proceed with wiring, it seems to make sense to get the rudder back on the plane so I can wire the light that is installed on the bottom fairing.
This requires
• Installing the HS
• Installing the VS
Then I can install the rudder
Here is the HS on the floor
Here is the HS on the fuse
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
