My RV-8 Build Log
RV-8
Elevator Re-Installation
Installed the through bolt for the elevator horns per plans, using three washers per side between elevator horn and bearing.
Plans for Elevator Horn
Installing AN Hardware
Elevator Horns assembled.
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
