Brief Description: Left Brake Line Mounting Bracket to Left Gear Leg
Made the left brake line, from the mounting bracket to the left gear leg tower connector. Took the same garden wire template use for the right brake line, and reversed the bends to create a template for the left brake line. Checked the template against actual, fined tuned and proceeded to make an actual brake line using the 1/4" alum tube and my imperial tube bender.
Fitted the connectors to the brake line and flared. Installed the left brake line with little fuss.
Left Brake Line formed, connectors fitted and flared. Garden Wire template in background
Left Brake Line Installed at Mounting Bracket
Left Brake Line Installation, Bracket to Left Gear Leg Connector.
