Brief Description: Making Right and Left Brake Line - Mounting Bracke
Fortuantely, realized I could reach the brake line in the right gear leg tower by climing in the fuse and reaching through... This was awsome, but it also led the the realization that a few adjustments were still needed on the brake line. After mangling a bit to get the right shape that I coold also get my hand around to tighten the connector... it was time to re-make the brake lne using this one as a template. It seems virtually every line I have made so far, vent, fuel or brake, I have made at least 3 times...
The third attempt fit perfectly, both connectors screwed on immediately. Had to ensure the brake line routing does not interfere with the vent line routing in the gear leg. Clearance is excellent. Now on to the left brake line.
