Brief Description: Brake Line - Reservoir to Brake Cylinders
Installed the 90 degree elbow fittings in the bottom of the brake cylinders with an approximate 10 degree inward angle, and installed the 90 degree brass fittings for the flex line in the top of the brake cylinders with an approximate 5 degree inward angle.
Installed the Nylon Tee with thread sealant on the brake reservoir, and started planning the installed of the flex brake line from the Nylon Tee to the brass fittings on the Brake cylinders.
The flex lines will run in parallel from the nylon tee to the mounting bracket previously installed, tie wrapped to the existing left brake line previously installed from the mounting bracket to the left gear leg well. A couple of clamps hold the flex line to the metal flex line after the mounting bracket to the brake cylinders.
Brake Lines Connected to Cylinders
Nylon Tee Installed with Thread Seal
Starting to run the flex line, Nylon Tee to Brake Cylinders
