Brief Description: Brake Line Connector Mounting Bracket
Installed the Brake Line 90 degree elbow mounting bracket as speciified, except, the 2006 plans call for flush rivets, but I see no gain in having to maching countersink the mounting bracket for the flush rivets, especailly since the plans do not mention counter sinking, so used same size universal rivets instead.
Installed the 90 degree elbow connectors for the brake line routing to the connectiors in each left and right gear leg tower.
