My RV-8 Build Log
Date:  4-5-2011
Brief Description:  Trimming the HS rear Spar for EL fitment
Trimming the HS rear spar for EL fitment. To enable the elevator enough down travel, need to trim part of the HS rear spar. But just enough, and no more... Marks indicate 1st, 2nd and 3rd trim lines if required.
Used the dremel to cut the rear HS spar. Worked very well. Van's calls for between 25 and 30 degrees down travel. After trimming, I have ~ 28 degrees.
Measure twice, cut once?
Ready to trim...
Ready to trim...
