My RV-8 Build Log
Date:  4-6-2011
Number of Hours:  3.00
Brief Description:  Drilling the EL Horns
Drilling the EL Horns. A bit nerve racking, really don't want to screw this up. Made a guide as directed by the plans, and drilled the horns.
Afterward, I noted the horns do not perfectly align where the torque tube will eventually connect. However, after further reading, this is normal and the plans call for drilling the torque tube hold by measuring for the closest EL horn... whew...
Let's Drill..
Let's Drill..
Pilot hole drilled
Pilot hole drilled
Passes Inspection, bolt aligns nicely
