Bill's RV-14A Project
RV-14A
Emp-Vert.Stabilizer
11-25-2013
Vertical Stabilizer Spar and Rib Deburring
I removed all the clecos and disassembled the vertical stabilizer.
I deburred all the holes in the ribs and spars to remove the little chips of aluminum that are created during the drilling process.
The edges of all the parts were also deburred on the scotch brite wheel and air die grinder using a mini scotch brite attachment.
A little more preparation is required before I prime these parts. I'll be using a water-based primer from Stewart Systems called EkoPrime.
http://www.stewartsystems.aero
Vertical Stabilizer Parts Deburred
RV-14A Home
273
Emp-Elevator
Emp-Hor.Stabilizer
Emp-Rudder
Emp-Vert.Stabilizer
Fuse-Aft Fuselage
25
Registration
Shop-C-Frame Table
Shop-EAA Workbench
Shop-Parts/Easel
Shop-Spray Booth
Shop-Spray Table
Shop-Storage Shelves
