Brief Description: Vertical Stabilizer Skin Test Fit
I test fit the vertical stabilizer skin to the spars and ribs. The VS-705 Nose Rib and VS-706 Tip Rib had to be fine tuned to get the right fit. This involved using my scotch brite wheel to shape the front end of each of the ribs a litlle more than what I did previously. After this fine tuning, the skin fit nicely onto the spar and rib structure.
I final drilled #40 all the 3/32 holes in the skin to the vertical stabilizer structure.
Next will be to disassemble everything and prepare the parts for priming.
