Brookes Web Site
Date:  7-20-2010
Number of Hours:  8.00
Brief Description:  More sanding
Finished removing gummy epoxy. Wing back on airplane. Scott Swing showed my how to block sand and emphasised the object was simply to remove high spots. I spread a dry black powder guide coat and finished block sanding bottom of pilot side wing and strake.
Removed tape from nose light lens and lense popped loose. The silicon caulk I used days before must have been bad because it never really set up.
After block sanding with guide coat.
Copyright © 2001-2018 Matronics. All Rights Reserved.
