Spent a great deal of time tweaking and adjusting door closing mechanism. Cut out a quarter of the captivator wide area washers so that I could mount it as high as possible. Used threaded rod between rod ends. Moved the nylon roller almost fully aft in the slot. Installed the longer springs.
In the end it looks like a good intstallation. I'll check it again when we run the gear with hydraulics
