Started the day verifying that center seat support was positioned correctly. It was! Trimmed up glare shield for a better fit. It is ready for upholstery.
Removed cowling and installed complete cooling plenum to ensure no interference from cowling. Reinstalled top cowling. Marked the aft 6 inches straight accross for cutting. Removed cowling and cut off those 6 inches. Sanded both parts of the upper cowling for later glassing. Bondoed pieces of 3/8 divinicel foam under the aft edge of the forward part of the upper cowling to be used later to attached the 2 pieces together again.
