Brookes Web Site
Date:  4-26-2011
Number of Hours:  4.50
Brief Description:  Cowling
Attached upper and lower cowling and worked out a plan to modify cowling to fit airplane. It turns out that I will attach both top and bottom half forward flanges to the fuselage as built. All the modifications will be done aft of this connection. Note the gap on the side between the upper and lower halves resulting from the 2 inch increase in fuselage height.
Fitting Cowling
Fitting Cowling
Cowling being fitted
Copyright © 2001-2017 Matronics. All Rights Reserved.
